120ohm CAN Resistor Lead
Missing a CAN Bus terminating resistor in your network? Plug this 9 inch banana plug test lead into your OBD2 breakout box to add 120Ohms back into the network. Use 2 of the 120 ohm leads if you are bypassing both resistors or setting up communication on the bench.
Features
Standard 4mm ba... See More
